How to remove and replace headlight bulb?
MEATLOCKER
What does one have to do in order to remove and replace a headlight bulb in the car listed above?
Dec 17, 2008 at 5:39 AM
  • 110,248 POSTS
You should be able to gain access to the bulb from under the hood. Follow the wiring to the assembly (under the hood) and it should lead you to a black socket that will screw out and in. Turn it counter clockwise to remove. replace the bulb, and reverse the sequence.
Dec 24, 2008 at 11:33 AM
HODO74
How do I remove the light to get to the bulb and which is high and which is low?
Apr 8, 2021 at 2:39 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. This is a tutorial for you to view on how to replace a headlamp bulb:
https://www.2carpros.com/articles/how-to-replace-a-headlight-bulb
I've attached picture steps below as well on how to replace headlamp bulbs on your vehicle. The inner bulbs are the HI-Beam. The Outer bulbs are the Headlight. Hope this helps and thanks for using 2CarPros.
Apr 8, 2021 at 12:23 PM
