fan relays?
CHEVYONLYGUY
where is the radiator fan relays?
Oct 17, 2010 at 7:02 AM
  • 55,588 POSTS
Hello Chevyonlyguy,
I did some research and found this diagram for you. Check out the diagrams (Below). Please let us know what you find.
Nov 22, 2016 at 10:25 AM
BELDEN
Put a new radiator hose on. Car was over heating. To be safe want to install new fan relay. Manual is not very specific. Yes, it is cooling fan relay. 1997 Buick LeSabre Custom.
Sep 23, 2019 at 7:27 AM (Merged)
CJ MEDEVAC
  • 11,000 POSTS
Here is a guide to help you test the (2 high and low speed 6 and 7) relays which are on the fire wall the diagrams below will show you.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed two options for the locations
JHAMBRICK
What is the location of the cooling fan relays. The fan doesn't come on and I was told to check the relays.
INTERNETMECHANIC
  • 700 POSTS
If you turn on the ac does the fan run? Some systems, if you use a jumper wire at the datalink connector to access mil codes, the fan will run. The relays should be under the hood, driver-side front.
https://images.2carpros.com/forum/automotive_pictures/512072_buick_lesabre_fan_relay_1.jpg
