1998 Buick Lesabre dash venting
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
444FIRE
  • 21 POSTS
dash vents don't blow a/c @ start-up - blows onto windshield. 3-5 mins. a/c comes out dash vents. why and how to fix. thanks.
Feb 24, 2010 at 12:17 AM
DENNYP
  • 1,824 POSTS
Are you saying it is slow to switch from windshield to dash vents?
Feb 24, 2010 at 2:59 PM
444FIRE
  • 21 POSTS
Yep - very slow. When set on "auto" with temp @ 60 it doesn't blow out the dash vents, even when I manually direct it to "mid".
Feb 24, 2010 at 10:34 PM
DENNYP
  • 1,824 POSTS
Air Delivery Improper
Step
Action
•Engine idling.
•Check for vacuum on the main vacuum supply source at the HVAC Programmer Vacuum Line Connector.
Is vacuum present?
Go to Step 2
Go to Step 5
2
Using a vacuum pump, apply vacuum to each actuator line at the HVAC Programmer Vacuum Line Connector.
Do all the lines hold vacuum?
Go to Step 3
Go to Step 4
3
Inspect the actuator doors for binding.
Did you find and correct the condition?
Go to Step 7
Go to Step 6
4
Inspect each vacuum line for an open or restriction, if no open or restriction was found replace the appropriate actuator.
Go to Step 7
5
Locate condition and restore vacuum to source line.
Go to Step 7
6
Replace the HVAC Programmer.
Go to Step 7
7
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Feb 25, 2010 at 5:36 AM
444FIRE
  • 21 POSTS
good info denny - where is the programmer vac line connectors located? how do I access them? Thanks.
Feb 25, 2010 at 11:05 PM
DENNYP
  • 1,824 POSTS
If I remember correctly, they are under the passenger side of dash.(behind glove box)
Feb 26, 2010 at 3:03 AM
