1998 Buick Lesabre blower & heater module
JERRYLPHILLIPS
Heater problem
1998 Buick Lesabre 6 cyl Front Wheel Drive Automatic
the blower fan has quit...we've replaced the climate controll unit inside the car but still the fan has quit. It worked for about a day...was told that there is a module that may be bad.. any futher advise?
Nov 12, 2008 at 8:30 AM
  • 110,248 POSTS
Hi:
I recommend you check for power to the motor before replacing anything. If there is no power there, work backwards until you find it. It could be something as simple as a blower motor resister or the relay. However, if you are getting power to the motor, it will need replaced.
Let me know if you have any specific questions that I can help with.
Nov 13, 2008 at 1:18 PM
