1998 Buick Lesabre
112,636 MILES • 6 CYL • FWD • AUTOMATIC
GEARHEAD!!
I have a no start condition. It cranks over fine and sounds like it's firing but won't start. It was missing and running crappy last month and I replaced the coils and it ran good after that until today. It was 30+ degrees today so it wasn't because it was too cold. This condition happened one othe time but it snapped out of it.
Thanks in advance!
Mar 4, 2009 at 8:59 AM
ZACKMAN
  • 4,202 POSTS
Check fuel pressure at the fuel rail (should be about 45 psi). Also check for spark at the plugs.
Mar 4, 2009 at 1:31 PM
GEARHEAD!!
Thanks or your reply. I checked for fuel pressure and there isn't any. I'm assuming it could be the pressure regulator or fuel filter. It had a new pump put in not long ago. Anyone have any ideas?
Mar 9, 2009 at 2:07 AM
ZACKMAN
  • 4,202 POSTS
You may want to check for voltage at the fuel pump B+ connector. If you have power at the harness, the pump is bad. Before replacing the pump though, you may want to replace the fuel filter as well.
Mar 10, 2009 at 12:56 PM
GEARHEAD!!
Thanks Zackman. As soon as it warms up I'll check it out.
Mar 10, 2009 at 11:27 PM
ZACKMAN
  • 4,202 POSTS
Sure thing...
Mar 11, 2009 at 1:52 PM
