1997 Buick Lesabre Turn signals won't blink
172,518 MILES • 6 CYL • 2WD • AUTOMATIC
KARMASMATIK
My turn signal lights will turn on but they no longer blink, they are just a steady light. However, when I switch on my hazard lights all four blink and behave normally (the same four lights as the turn signals). This problem is consistent with all four signal lights. I assume I just need to replace an electrical relay somewhere but don't really know where to look for it.
Jan 31, 2010 at 8:13 AM
  • 75,988 POSTS
Test or Swap the turn signal flasher in the left kick panel if problem persist-check and test the turn/hazard switch
Jan 31, 2010 at 8:24 AM
