1997 Buick Lesabre Shuts off while running
JFZIEGER
Electrical problem
1997 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I have a 1997 Buick that starts and runs then after approximately 5 or 6 miles it just shuts off while I am still driving it. After 10 or 15 minutes when it cools down it will start again, but it seems after it gets hot again it just shuts off while I am driving. I replaced the CAM sensor and the battery because that is what the mechanic said was the problem. I think it may be the fuel pump. Can you please give me your opinion.
Oct 19, 2010 at 10:26 AM
SATURNTECH9
  • 30,868 POSTS
Do you have any code's in the computer?It sound's more like a sensor getting hot and failing like a crank shaft sensor.
Oct 19, 2010 at 1:46 PM
JFZIEGER
[quote:f5f566477e="saturntech9"]Do you have any code's in the computer?It sound's more like a sensor getting hot and failing like a crank shaft sensor.[/quote:f5f566477e]
The code said it was the CAM sensor, but that did not work...I will see if I can get it back on the scanner and check for more codes...thank you
Oct 20, 2010 at 4:46 AM
SATURNTECH9
  • 30,868 POSTS
Alright let me know if you have code's and what the code number's are.
Oct 20, 2010 at 6:57 AM
