1997 Buick Lesabre Reset Button
TOMMY_K0963
Engine problem
1997 Buick Lesabre Engine Size unknown Two Wheel Drive Automatic 130000 miles
My car recently over heated. Now it wont start is their a reset button I need to reset so it will start? It turns over it just doesn't catch
Dec 26, 2007 at 5:29 AM
BLACKOP555
  • 10,386 POSTS
sounds to me that when you engine overheated it may have warped or cracked the heads causing in sufficent compression.
perform a compression test on each cylinder the lowest one should be no more then 25% less then the highest.
Dec 26, 2007 at 7:24 AM
