Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Engine
Symptoms
Overheat
1997 Buick Lesabre Overheating
1997 BUICK LESABRE
129,000 MILES • 6 CYL • 4WD • AUTOMATIC
EYESTONE
MEMBER
1 POST
Loosing coolant. Coolant getting in cylinders. No coolant in oil. Compression good. Head gasket?
May 10, 2008 at 12:45 PM
BLACKOP555
Experienced Mechanic
if the compression is good then i wouldnt suspect headgaskets, i would suspect a cracked engine block or more likely a bad intake manifold gasket.
May 10, 2008 at 1:35 PM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
