1997 Buick Lesabre oil pressure
DARKSTER
Engine Mechanical problem
1997 Buick Lesabre 4 cyl Front Wheel Drive Automatic
while driving my car my gauge for the oil went to nothing. i turned my car off and got to the shoulder of the road. my oil is full. i have replaced the oil pressure switch - no help. gauge still not moving now car when started sounds very rough. any suggestions?
Jul 26, 2008 at 8:19 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-could be an oil pump issue with pressure relief valve/engine bearings
Jul 26, 2008 at 8:33 AM
BLACKOP555
  • 10,386 POSTS
soudns like tis not a faulty with the sensor or sending unit.
sounds like something is bad with the pressure and since it is runnign rough i WOULD STOP RUNNING IT ASAP UNTILL YOU TAKE A LOOK AT THE OIL PUMP.
normally if the guage is bad it wont mkae loud noise such as you are observing.
Jul 26, 2008 at 8:46 AM
