1997 Buick Lesabre I have recharged refrigeration system
177,000 MILES • 6 CYL • FWD • AUTOMATIC
PARREPAIR
after recharging system pressure reading is good but still pushing hot air in passenger compartment I checked fuses and circuit breackers on passenger side where fuse goes theres nothin there to hold a fuse
Jun 21, 2010 at 6:21 AM
BLACKOP555
  • 10,386 POSTS
sounds to me like your vehicles air blend door is not functioning properly. does it change duct positions just fine? do you notice that the vehicle temp will change from very hot with knob on hot to outside air temp on cold or is it the same hotness no matter what.
Jun 22, 2010 at 4:52 AM
PARREPAIR
it has a slide control that seems to be not after charging the system under the hood pipes going to passenger compartment were cold had a good pressure but still pushing hot air now seems like I have another problem now I have no freon in system so its time for an A/C certified tech to check system thank you for your help
Jun 22, 2010 at 9:16 AM
BLACKOP555
  • 10,386 POSTS
yes sounds like it would be time to take it in and have that checked out. sorry we couldnt fix it. good luck having it fixed!
Jun 23, 2010 at 4:26 AM
