my turn signals were not blinking?
ANA09
1997 Buick Lesabre
My question is what is wrong with my turn signals? I noticed on Saturday (09/18/10) that my turn signals were not blinking. The lights would stay solid. I did check for a light to be burnt out but there was no lights burnt out. Later Saturday night I took the flasher fuse out of the fuse box for a little bit then pluged it back in. The car sat over night and the Sunday (09/19/10) morning the turn signal worked normal. Then yesterday (09/23/10) the turn signal stopped working again. I need to know what to do. I did buy a new fuse but the fuse that is in the car is square and the plugs do not match the round on that I bought from Auto Zone.
Sep 24, 2010 at 2:00 AM
  • 75,988 POSTS
Hazard Flasher Part no. 491391
Sep 24, 2010 at 2:09 AM
WRENCHTECH
  • 20,758 POSTS
If this is happening equally to both sides, then it's likely a bad turn signal flasher. It may have two of them, one of hazards and one for turn signals.
Sep 24, 2010 at 2:10 AM
ANA09
Hazard light work fine though. I tested those and they flash fine. Also the fuse that is in the car does not match the fuse I bought for it. Unless I am not looking in the right place
Sep 24, 2010 at 2:35 AM
WRENCHTECH
  • 20,758 POSTS
Your not looking for a fuse. Your looking for a flasher.
Sep 24, 2010 at 2:39 AM
ANA09
Ok I need to know where to look then...
Sep 24, 2010 at 2:55 AM
WRENCHTECH
  • 20,758 POSTS
On the top side of the sound insulator on the driver's side.
https://images.2carpros.com/forum/automotive_pictures/561653_Turn_signal_flasher_97_Lesabre_1.jpg
Sep 24, 2010 at 3:17 AM
GOLIATH2613
  • 5 POSTS
My hazard lights work but blinkers don't, how do I know if I need to replace the turn flasher( looks new ) or is it something else
Mar 5, 2014 at 11:18 PM
GOLIATH2613
  • 5 POSTS
My hazard lights work but blinkers don't, how do I know if I need to replace the turn flasher( one looks new ). But looking up under the dashboard under the steering wheel it looks like another turn flasher also semi-new looking, neither are labled *turn flasher* or have the part no. 491391
Mar 6, 2014 at 2:56 AM
