1997 Buick Lesabre Heating problems
105 MILES • 6 CYL • 2WD • AUTOMATIC
PERKYPAUL
The only way I can get any heat is to set the temp. as high as it will go. It is an electronic heating/cooling system. My exterior temp. readout is way off. Could that be what is effecting my heating problem?
Apr 8, 2008 at 3:47 AM
2CARPRO JACK
  • 11,533 POSTS
Possibly, but you need to find the blend door to be sure it is moving when lower temps are selected. Sometimes the motor wont work all the way causing what you describe
Apr 10, 2008 at 5:57 AM
