1997 Buick Lesabre Heater blowing cold air
JEFFJODE
Heater problem
1997 Buick Lesabre 6 cyl Front Wheel Drive Automatic 100k miles
Heater has worked fine all winter. Today I replaced the battery, and since then all I get is cold air blowing out the vents. I've read on other sites that this is a result of the indoor/outdoor air gate not closing 100%. Is this probable?
Jan 24, 2008 at 11:14 AM
BMRFIXIT
  • 19,053 POSTS
[quote:31c1734aec="jeffjode"]Heater problem
Heater has worked fine all winter. Today I replaced the battery, and since then all I get is cold air blowing out the vents. I've read on other sites that this is a result of the indoor/outdoor air gate not closing 100%. Is this probable?[/quote:31c1734aec]
check blend door and its operation
unplug the bcm and plug it back in
or take it fuse out and put it back in
Jan 27, 2008 at 7:19 AM
JEFFJODE
[quote:be3c426738="BMRFIXIT"][quote:be3c426738="jeffjode"]Heater problem
Heater has worked fine all winter. Today I replaced the battery, and since then all I get is cold air blowing out the vents. I've read on other sites that this is a result of the indoor/outdoor air gate not closing 100%. Is this probable?[/quote:be3c426738]
or take it fuse out and put it back in[/quote:be3c426738]
Thanks for the help. Not really sure what the problem was. I was having trouble with the climate control, so I did send it in to get repaired. I reinstalled the climate control, and I was still only getting cold air. So I removed the glove box, and manually shut the blend door. After that, heater worked fine, and so did the operation of the blend door.
Jan 31, 2008 at 7:28 AM
