1997 Buick Lesabre
1997 BUICK LESABRE
149,000 MILES • 6 CYL • FWD • AUTOMATIC
BOWWOW
what all can cause da car to run hot, and will a car stop if it is very low on oil?
Oct 14, 2008 at 8:06 AM
DENNYP
  • 1,824 POSTS
Poor coolant condition, low coolant level, cooling fans not working, cooling system leaks allowing air into the system, bad water pump, restriction in the cooling system, excessive debris buildup in radiator cooling coils, blown head gasket, cracked cylinder head, ect..... You should not run it low on oil.
Oct 15, 2008 at 1:59 PM
