1996 Buick Lesabre 1996 Power Steering Wheel
1996 BUICK LESABRE
88,000 MILES • 6 CYL • FWD • AUTOMATIC
RAL_RIFFRAFF
Mfg: Buick
Model: LaSabre
Year: 1996
Problem: the steering wheel was very hard to turn. So basically there is no power steering.
The belt tensioner froze thus damaging the power steering pump. The shop replaced the belt, belt tensioner (1.060 SP) and power steering pump.
Question:
In the process of replacing the power steering pump, belt (which loops around the power steering pump) and belt tensioner, is the engine, transmission or any part of the coolant system (hose, etc) touched or removed in anyway? In other words, if not done properly can coolant leak into the engine or transmission?
Thank you,
ral_riffraff
Mar 15, 2010 at 7:18 AM
DOCFIXIT
  • 18,828 POSTS
Radiator drained and outlet hose removed also heater hoses removed. But not sure hose R&R would cause coolant to be in engine.
Mar 15, 2010 at 7:37 AM
