1996 Buick Lesabre
DODGERONE
  • 1996 BUICK LESABRE
Engine Performance problem
1996 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I installed a transmission and when istart it up it shuts off in about 5 seconds.
Thursday, April 30th, 2009 AT 1:08 PM
2CARPRO JACK
  • 11,533 POSTS
What is it losing when it dies, spark or fuel? Did you get all the grounds tight?
Saturday, May 2nd, 2009 AT 8:12 AM
DODGERONE
The car ran fine when idrove it in the garage. There wwas no grounds bolted to the bell housing. It dont lose fuel and power stays to module, it will start right back up after it shuts off. I put afuel pump in changed computers, no codes in it. The grounds are bolted on the sides of the block that ican see.
Saturday, May 2nd, 2009 AT 11:09 AM
2CARPRO JACK
  • 11,533 POSTS
Those had issues with crank angle sensors, you may hvae one acting up, they dont always set codes
Saturday, May 2nd, 2009 AT 2:35 PM
Related Transmission Replace/Remove Content
Automatic Transmission Replacement
VIDEO
