1995 Buick LaSabre with approx. 60,000 miles. I believe it has GM OBD 1.5 since it has the 16 pin connector.
I am receiving engine codes P0321, P0341, and P0361 when an Actron 9140 scanner is connected.
The scanner print out lists the following for the scan codes:
[b:ea410162dd]P0321[/b:ea410162dd] - Ign system problem 18X interrupts lost signal.
[b:ea410162dd]P0341[/b:ea410162dd] - Ign system problem Camshaft sensor intermittent signal
[b:ea410162dd]P0361[/b:ea410162dd] - Ign system problem Electronic spark timing EST not toggling.
I have replaced the [b:ea410162dd]camshaft sensor, O2 sensor, and the throttle position sensor [/b:ea410162dd]and the light is still on.
Any idea what is causing this? :?:
Jan 7, 2007 at 3:50 AM
