Other Category problem
1995 Buick Lesabre V6 Front Wheel Drive Automatic 222444 miles
My car wont start, it turns over but,does not start, at first i think fuel pump, have it towed home prime it, still wont start, if you listen in the tank the pump does kick in but, the car wont start. Next thing is it getting spark, use timing gun it has good spark, moving on remove spark plug test for compression getting compression on two spark plugs in front did not check back plugs to hard to reach. where should I go from here I think possibly timings jumped or computer what would you suggest I try next?
Dec 4, 2007 at 6:03 AM
