The car has 90,000 miles on it. 3.8 engine
About 3 months ago I had the stock 200 degrees thermostat changed out with a 'failsafe thermostat 180 degrees.'
Since then the car runs about 160-170 degrees. Is that normal for it to run lower than what it is intended for?
Also, recently (a month) the temperature gauge can read 200-210 degrees when it is in idle for a while but while driving it drops back down to 160-170. But this only happened twice in that time period, it is not consistent.
Did I possibly buy a faulty thermostat?
Nov 28, 2007 at 10:53 AM
