1995 Buick Lesabre WEIRD TEMPERATURE READING!
CARDOBCF
The car has 90,000 miles on it. 3.8 engine
About 3 months ago I had the stock 200 degrees thermostat changed out with a 'failsafe thermostat 180 degrees.'
Since then the car runs about 160-170 degrees. Is that normal for it to run lower than what it is intended for?
Also, recently (a month) the temperature gauge can read 200-210 degrees when it is in idle for a while but while driving it drops back down to 160-170. But this only happened twice in that time period, it is not consistent.
Did I possibly buy a faulty thermostat?
Nov 28, 2007 at 10:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:89c8f9ad2b="cardobcf"]The car has 90,000 miles on it. 3.8 engine
Did I possibly buy a faulty thermostat?[/quote:89c8f9ad2b]
Every thing is possible
I will take radiator cap off drain little down the coolant get a thermometer
Stick it in the radiator make sure its in contact with coolant start the engine and let it warm up watch the thermometer u will know when the thermostat open and then make the decision if the thermostat a good or bad one.
Also check the wires on the temp sending unit
Good luck
Nov 28, 2007 at 11:58 AM
