1995 Buick Lesabre Throttle Position Sensor Replacement
91,000 MILES • 6 CYL • FWD • AUTOMATIC
LOTTAREPAIRS
I replaced the tps after the engine began racing or dying at just about any moment. I removed the old one then put the new one in without any other action. The next day it started happening again. The engine began racing or dying. Is there something I need to do other than take it out and replace it? e.g. disconnect the battery??
Sep 21, 2008 at 12:45 PM
  • 75,988 POSTS
Inspect/clean/test the idle air control valve and also check the PCVand EGR valves.
Sep 21, 2008 at 12:55 PM
