1995 Buick Lesabre Stalls
CHEVY134
Electrical problem
1995 Buick Lesabre 6 cyl Two Wheel Drive Automatic
I am working on a 1995 Buick Lesabre. It will stall interm. just like you shut off the key. No codes are being set. When this happens, I can watch data on the Tech 2 & it will loose communication with the ECM every time it stalls. Also the volt and ses light
flashes & various relays energize & de energize. I have tried a good ECM.
Oct 7, 2010 at 7:11 AM
  • 75,988 POSTS
Try having the charging system checked out-if the PCM is not getting the correct voltages it will go haywire and a malfunctioning ignition switch
Oct 7, 2010 at 9:59 AM
