1995 Buick Lesabre Problems with electronics
142,000 MILES • 6 CYL • AWD • AUTOMATIC
SPEEDY4442001
Problems with electronics. The power windows will work on the driver side or passenger side every other time, if I open and close the driver door, they will then work. Passenger side blinker does not blink, it does light. Got cut off by a semi while doing about 50 mph, the air bag light came on and wouldn't go off. It then started flickering and eventually went off. A few hours later got in & turned on the key and the air bag went off. It got so hot that it melted the bag, then the horn started going and wouldn't shut off. That too eventually stopped. Drove the car about 1/2 hr home and it still was quite hot on the column around where the air bag goes. I do not know where to start to figure out the problem. Any help?
Aug 10, 2009 at 8:37 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds liek several different issues.The windows may be caused by broken wiring where it passes from body to door on drivers side.If there is a problem with the master switch it wont let the other side work either.The column/air bag issue I would have a shop look at immediately,they are nothing to mess with and it sounds like you have a dead short if things are melting, it could potentially cause a fire.Blinker.... is it just one light or one side of the vehicle that doesnt flash? may just be a bulb or bad connection at the bulb, start there
Aug 13, 2009 at 12:30 AM
