1995 Buick Lesabre MASTER CYLINDER
DROOP
Brakes problem
1995 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I just bled my brakes. The front diver side bled good. The passenger side was hardly coming out. There was hardly any pressure when I pumped the brakes. My car is not leaking brake fluid. Is the problem the master cylinder?
May 22, 2008 at 8:27 AM
MERLIN2021
  • 17,250 POSTS
Is it a low pedal problem? Chech the left rear wheel cylinder before you junk the master, you have a diagonal brake system in yours, meaning the right front, and left rear are paired off the master, and the left front and right rear is the same way... a leak in the rear will affect the opposite front!
May 22, 2008 at 8:32 AM
