HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Fuel System
Fuel Pump
Location
1995 Buick Lesabre Fuel pump
KELLYSUMPTERSR
MEMBER
1995 BUICK LESABRE
1995 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I have cut a hole in the trunk and located the fuel pump. How do you remove the fuel pump from the tank?
Sunday, June 22nd, 2008 AT 12:39 PM
BLACKOP555
MECHANIC
If its plastic type you will need a big pair of pliers or a large oil filer remover wrench to turn the ring off.
If its the metal type you will have to use a metal hammer and a brass punch to turn off the old ring.
Sunday, June 22nd, 2008 AT 1:26 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Location Content
1992 Buick Lesabre Where Is The Fuel Pump Switch...
Can You Tell Me Where I Could Find The Fuel Pump Switch Because My Vehicle Shutoff And I Can't Start It And I Know That This Is My Problem.
Asked by
ecool123
1 ANSWER
3 IMAGES
1992
BUICK LESABRE
2001 Buick Lesabre Fuel Pump
On This Model Car Is The Fuel Pump Located In The Gas Tank Or Exterior?
Asked by
shatara33
2001
BUICK LESABRE
Fuel Pump? Or Something Else
1995 Buick Lesaber Ok So I Put Some Gum Out In It With The Last Oil Change And It Started Sputtering Periodicly So I Changed The Fuel Filter...
Asked by
tcooperson
1995
BUICK LESABRE
Fuel Pump Relay Problems?
After Checking Fuel Pump And Replacing Fuel Pump Relay I Finaly Got The Car Started But As Soon As I Try To Give It Some Gas The Car Wants...
Asked by
papaduckie
9 IMAGES
1999
BUICK LESABRE
1994 Buick Lesabre Fuel Pump Fuse
Electrical Problem 1994 Buick Lesabre 6 Cyl Front Wheel Drive Automatic The 20amp Fuel Pump Fuse Keeps Blowing. I Have Replaced The...
Asked by
bkmatthews
1994
BUICK LESABRE
VIEW MORE
Fuel Pump Replacement
Fuel Pump Pressure Test
Engine Not Starting
