1995 Buick Lesabre fuel injectors
170,000 MILES • 6 CYL • FWD • AUTOMATIC
GREGALLAN
how do you replace or clean injectors? 2 and 5 not fireing
Mar 20, 2008 at 12:23 AM
MERLIN2021
  • 17,250 POSTS
If you have an ohm meter, check them against the ones that do fire...if theytest bad replace them, if they test OK get a noid light and check the connectors...could be the harness...To replace them you unbolt the fuel rail, and pull up, all injectors on the rail will come out...use NEW O rings, and a small dab of engine oil to aid with reinstallation.
Mar 20, 2008 at 1:13 AM
