1995 Buick Lesabre exhaust manifolds turning red
1995 BUICK LESABRE
100,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHN1617
I took the motor out to put another transmission on it and put it all back togather and now when i start it up the exhaust manifolds get red hot.i thought maybe the cataletic converter was doing it but i disconected the exhaust before the converter and it still gets red.the motor has no miss or hesitation in it like the timing would be off it runs smooth.i was wondering if it could be a problem with the fuel like running to rich or lean or maybe the fuel pressure regulator? wondering if anyone had any ideas? thanks alot.
Jul 21, 2008 at 11:29 AM
BLACKOP555
  • 10,386 POSTS
it gets redhot at idle?
i would suspect a severly lean engine fuel mixture, could even be rich.
even if the timing is off it could be causing that to happen also.
Jul 21, 2008 at 1:09 PM
JOHN1617
yes it takes about 3 or 4 min. to get red thats at a idle.
Jul 22, 2008 at 8:42 AM
BLACKOP555
  • 10,386 POSTS
check for a lean air mixture if thats the case. you have a bad o2 sensor or a vaccum/air intake?
Jul 22, 2008 at 12:35 PM
