1995 Buick Lesabre engine swap 92-94
WILDFIREV9
  • 49 POSTS
Engine Mechanical problem
1995 Buick Lesabre 6 cyl Front Wheel Drive
I have a 95 L code car (Lesabre) with the earlier design (93-94) oil pan setup engine.
will a 92 L code engine work properly in a 94-95 L code car?
Oct 25, 2010 at 6:52 AM
HMAC300
  • 48,601 POSTS
as long as the engine will fit ok you sholdn'thave any problems. but if the later model pan has bolts going to the trans you need them so you may just be able to change thepans.
Nov 3, 2010 at 11:41 AM
