While driving, electrical system and engine shut down without warning. After coming to a stop, nothing happens when you turn the key, no cranking, no clicking, no dash lights.
10 minutes later car started right up, only to completely stop again after about 5 minutes.
Simple answer?
SPONSORED LINKS
Friday, August 21st, 2009 AT 9:13 PM
JDL
MECHANIC
Hello, I'd have to make sure the battery has a full charge and the connections are all good. I might have to check the feed going to and from the ignition switch.
Saturday, August 22nd, 2009 AT 12:28 PM
SABRE MANNN
MEMBER
Check your harmonic balancer and pick up sensor or maybe you need a new key made from the dealer
