replaced cam sensor,maf sensor,crank sensor,fuel pump,and filter,air filter,oil and filter,master cylinder,plugs and wires,new battery,a few vaccum lines and the check engine light is constantly on and it stalls randomly and putters.had it scanned got a new computer for it thinking its a possibility and still same problem.could it be my ignition module,iak,or oxygen sensor?when it was scanned after all that my mechanic said it was a hard code for the cam sensor.so i replaced it again incase of defective parts and still same problem.i also have two cables that connect to my positive end of my battery.but it looks like how it came from factory but im not sure.after all that my mechanic said it could be a bad wire coming from the cam sensor and there is three of them.is there a common spot where this happens?help me
May 23, 2008 at 12:46 PM
