1995 Buick Lesabre Brake Fluid Leaking
185,000 MILES • V8 • 2WD • MANUAL
RLDUDEN
Brake fluid is leaking from the round master brake cylinder behind the fuild reservior. Is this an easy repair or is mechanic only territory. I am going through a bottle fluid every 2 1/2 weeks or so. I know I need to get it fixed, but I dont' want to spend that much on this car. Any Advise would help.
Thanks
Nov 10, 2009 at 11:40 AM
  • 110,248 POSTS
If you have mechanical ability, you can do it. Basically, you remove the two brake lines from the MC and then unbolt if from the brake booster. Once it's removed, the new one goes on in the opposite order. The only difference is you must bench bleed the new one. The directions should be with the new MC. If they are not, let me know.
Nov 23, 2009 at 1:51 AM
