1995 Buick Lesabre 6 cyl Front Wheel Drive Automatic
Hwhy won't my car start?
Jan 6, 2009 at 2:08 AM
DE772601
MEMBER
Hello well there could be a number of reasons why. First check to see if the battery is holding a charge and then check the starter. If the car is cranking but will not fire then check for spark and if that is ok then check fuel presure. This should start you in the right path.
