Hello well there could be a number of reasons why. First check to see if the battery is holding a charge and then check the starter. If the car is cranking but will not fire then check for spark and if that is ok then check fuel presure. This should start you in the right path.
Wednesday, January 7th, 2009 AT 5:10 PM
