1994 Buick Lesabre wont pick up speed
1994 BUICK LESABRE
175,000 MILES • 6 CYL • AWD • AUTOMATIC
OMISSTAB
  • 6 POSTS
Help!! We have a 1994 buick lesebra, we took the engine and transmission out and put it in a 1993 pontiac bonneville. Changed the wires, plugs, oil, oil filter. The car runs put it takes off slow. The gas pedal can be to the floor. When it gets to 20 the speed will pick up to normal. Any Suggestions?
Aug 4, 2009 at 6:52 PM
  • CAR REPAIR CONTRIBUTOR
Causes of Hesitation or stumbling
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 5, 2009 at 4:11 AM
