car runs then cuts off cranks back up but no speed
Oct 30, 2009 at 7:51 AM
JDL
✓Experienced Mechanic
Fuel pressure shows 40-47 psi. Any trouble codes? If your fully obd 1 compliant, you can check codes yourself.
Place jumper wire between A & B terminals of data link connector, turn key on, no crank, the check engine lite starts flashing, you count the flashes to get the codes.
Oct 30, 2009 at 7:59 AM
