1994 Buick Lesabre Transmission noises/engine noises
28,000 MILES • 6 CYL • FWD • AUTOMATIC
TAILKINKER
My car makes terrible noises when I put it inot reverse, and it doesn't go into gear. It also makes noises when shifting between 1st and 2nd gear. I haven't tried it on the highway for fear of getting stranded, so I don't know about the higher gears. It also makes some noise when its in park. The noise sounds like something rattleing against plastic. Could this be a transmission gone bad? I just got this car and had a 16 pt safety check and they said the transmission fluid looked good. There are no leaks that i can see.
May 27, 2008 at 7:07 AM
DENNYP
  • 1,824 POSTS
sounds like there was a mechanical failure inside the transmission. You should take it to a tranny shop.
May 28, 2008 at 3:17 PM
