1994 Buick Lesabre steering column
1994 BUICK LESABRE
FLORES
Steering problem
1994 Buick Lesabre 6 cyl Automatic
how do you take off a steering column on a 1994 buick lesabre
Jun 13, 2009 at 11:09 AM
BILLYMAC
  • 2,204 POSTS
Hi, remove cover under coloumn on dash.
you will see 4 bolts holding coloumn up remove the bolts unplug the elec plugcoloumn will drop down to seat.
now go under the hood the other end of the coloumn, you will see where the shift cable connects to the coloumn..
disconnect the cable.
now you will go back inside car look at bottom of coloumn you will see a rubber boot pull this boot up.
now you will see a pinch bolt going through the coloumn remove this bolt .
now you can pull coloumn straight out..
sounds harder then it is. good luck billymac
Jun 13, 2009 at 11:29 AM
