1994 Buick Lesabre Starting problems
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BICKHEM
I have had problems with my car starting. I have had the starter replaced, spark plugs changed, fuel pump replaced, and the CAM sensor replaced. What else could be the problem getting my car to start?
Apr 12, 2009 at 3:40 PM
  • 75,988 POSTS
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jan 6, 2020 at 7:40 AM
