1994 Buick Lesabre Shutting OFF
62,000 MILES • 6 CYL • FWD • AUTOMATIC
CHILLYDAN45
We had a 1994 buick that kept shutting off, we took it to the mechanic and he said it was a computer problem. We had the computer switched out and it ran good for a couple months now it is doing the same thing. It will run for awhile then just shut off while your driving or it wont even stay started long enough to go anywhere. Is it still a computer problem? Can you reset the computer?
Nov 20, 2009 at 2:07 PM
  • 110,246 POSTS
Has the check engine light come on? HAve you checked fuel pump pressure?
As far as resetting the computer, disconnect the battery for about 15 minutes. If there are codes stored, it should reset them.
Let me know what you find.
Nov 23, 2009 at 12:16 AM
CHILLYDAN45
yes the service light is on. I un hooked the power for 15 min and it didnt help,,,seems to me that its starving for fuel, but the mech,,,says that we have 40lbs of presure what do you think????
Nov 24, 2009 at 5:27 AM
  • 110,246 POSTS
It could be a few things. Have you had the computer scanned? IF the check engine light is on, chances are there is a trouble code there that will help identify where the problem is coming from.
Let me know. ALso, most nationally recognized parts stores will do it for free.
Nov 24, 2009 at 5:36 AM
