how do i open the radiator/where is it located at so i can check and see if there is fluid in the radiator?
Feb 26, 2009 at 10:57 AM
✓Experienced Mechanic
Hi:
I believe coolant is added through the overflow bottle on the passanger side under the hood. Follow the hose from there and it will lead you to the radiator which, if I'm correct, doesn't have a cap.
