1994 Buick Lesabre Oil Leak.......
1994 BUICK LESABRE
17,500 MILES • 6 CYL • FWD • AUTOMATIC
PUNISHER004
I have a 1994 Buick Le Sabre that only leak oil when the engine is running. I took it to a shop and was told it was the gasket for the "Oil Filter Housing" .
I have had the gasket replaced, but the leak still occurs when the engine is running.
THe oil runs down to the ground from the area of the oil filter housing loosing up to 2 quarts a day.
Can you give me any idea on where the leak is comming from ?
Thank You................................................
Aug 26, 2009 at 2:28 AM
SERVICE WRITER
  • 9,123 POSTS
You need to call the shop that diagnosed and repaired it. Tell them it is the same, they owe you an explanation.
Aug 26, 2009 at 2:35 AM
  • 31,937 POSTS
Hi there,
this is a huge amount of oil to be leaking, if the mechanic who did this job can't see where that is coming from, he must be blind, go find a mechanic that will fix this, i am sure that it will not be hard to locate.
mark (mhpautos)
