1994 Buick Lesabre No Power From Ignition
TEXAS409
  • 10 POSTS
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 160K miles
my car wont even turn over, exterior and interior lights, dash lights all come on and radio works.The Car Wont Even Attemp to Crank Up and have put brand new battery
Dec 28, 2008 at 11:07 AM
JAMES W.
  • 2,394 POSTS
Check to see if you have power to the small terminal on the starter solenoid when you turn the key to start. If you do, your starter is probably bad.
Dec 28, 2008 at 12:54 PM
TEXAS409
  • 10 POSTS
i tested starter with jumper cables and it cranked fine
Dec 28, 2008 at 3:09 PM
TEXAS409
  • 10 POSTS
and by the way i have an limited model.with a 93engine in it now&after replacing a 94,but both runs the same just a couple sensor swaps.
Dec 28, 2008 at 3:19 PM
TEXAS409
  • 10 POSTS
could it be VATS problem thats stopping it?
Dec 29, 2008 at 5:43 AM
JAMES W.
  • 2,394 POSTS
If you have no power to the small terminal on the starter solenoid with key in "start" position, I would suspect the ignition or neutral safety switch.
Dec 30, 2008 at 1:40 PM
