1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic
when driving the car will run great and then while watching an attached fuel pressure guage, the car will loose fuel pressure and stall, after sitting for awhile it will restart and fuel pressure is fine, have already replaced the fuel pump, can monitor all pids with my solus scanner, no codes mass air seem to be in spec, swapped out the fuel pump relay under the dash on the right kick panel. Still no change
SPONSORED LINKS
Tuesday, November 17th, 2009 AT 9:13 AM
