1994 Buick Lesabre Irregular engine shut off
80,000 MILES • V8 • 2WD • AUTOMATIC
MARK MOLLESON
I will be driving along with the car running fine. With no warning and no specific circumstances the car will just shut off and coast. I can shift to N and restart and proceed on. It has never failed to restart and most times starts on the first easy attempt. The car is in a GM service center. They can get the car to fail but because it starts right back up and does not leave a computer message, they cannot fix. You have any ideas??
Jul 25, 2008 at 1:49 AM
DOCFIXIT
  • 18,828 POSTS
Hard to believe Mr. Goodwrech cannot find problem.
Suggest they hook up a diagnostic scanner put it on drive test snapshot mode then drive car when it fails scanner will record what failed.
Jul 25, 2008 at 2:12 AM
MARK MOLLESON
GM Tech says that this year is no longer supported by computer system.
Jul 25, 2008 at 2:29 AM
DOCFIXIT
  • 18,828 POSTS
It is OBD1 it has an ECM and that requires them hooking up an older ODB1 scan tool and drive. They are probably not old enough to have worked on a 14 yr old car.
Good luck
Try and find a good independent shop
Jul 25, 2008 at 2:33 AM
MARK MOLLESON
The best we can come with is "find a good shop". If I could do that I would not be here.
Aug 11, 2008 at 7:45 AM
GSP1981
When car dies does security light come on just before. Aprox time driving before dies could be anti. theft problem.
Aug 27, 2008 at 1:42 AM
