If the engine light is not on, then a sticking throttle plate or linkage may be to blame, you will need a can of throttlebody cleaner and an old rag, and thoroughly clean the the throttle body, as far as you can go into it, of carbon. And do the same of the plate and linkage, you can hit the linkage with some wd40, and work it back and forth to loosen it up
Sunday, February 28th, 2010 AT 10:06 AM
