1994 Buick Lesabre Heater dosn't blow hot
100,000 MILES • 6 CYL • FWD • AUTOMATIC
FTEDIOUSLY
My heater blows, but the heat is luke warm, at best.
I notices that my temperature is reading about 140 degrees. I bought T-stat, but have not put it in yet, I just put one in a week ago that was good for 180 degrees . The auto store said I should put a 195 degree one in. I wasn't working well even before I put the ne 180 degree T-Stat, so I am moderatle optimistic that this will work. Any help would be appreciated.
Dec 18, 2007 at 2:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a02517bfdf="ftediously"]Heater problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 100000 miles
I notices that my temperature is reading about 140 degrees. I bought T-stat, but have not put it in yet, I just put one in a week ago that was good for 180 degrees . The auto store said I should put a 195 degree one in. I wasn't working well even before I put the ne 180 degree T-Stat, so I am moderatle optimistic that this will work. Any help would be appreciated.[/quote:a02517bfdf]
put the 195 degree in and flush heater core
remove two heater hoses run water and comp. air if possible
Dec 20, 2007 at 9:25 AM
FTEDIOUSLY
flushed core and changed antifreeze, put 195 degree T-Stat in and still have warm air on driver side and cool air on passenger side.
Checked the doors behaind the glove compartment they seemed to be working OK.
ft
Dec 29, 2007 at 7:18 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c9247b5140="ftediously"]flushed core and changed antifreeze, put 195 degree T-Stat in and still have warm air on driver side and cool air on passenger side.
ft[/quote:c9247b5140]
check temperature blend door electric actuator
Dec 29, 2007 at 12:16 PM
