1994 Buick Lesabre fUEL sYSTEM
J.MILLER
Engine Performance problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic
i HAVE REPLACED THE FUEL FILTER AS WELL AS THE RELAY AND THE CAR WON'T START BUT CRANKS FINE I CAN PUT STARTER FLUID IN AND IT START AND RUN FOR A FEW SECONDS THEN DIES THE FUEL PUMP SEEMS TO BE WORKING IT WHIZZES WHEN THE KEY SWITCH IS ON HAVE ANY IDEAL WHAT THE PROBLEM MIGHT BE ?
Apr 23, 2008 at 7:08 AM
SERVICE WRITER
  • 9,123 POSTS
Need to check the fuel pressure. The pump may be running, but may not be giving enough volume to create enough pressure.
Apr 23, 2008 at 7:58 AM
