1994 Buick Lesabre Electrical / weak spark problem
OLDTIMER10
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 175k miles
Spark plugs (new) show weak, arching, yellowish spark. Not a sharp, blue snap as normal.
Tested wires, ICM, coils, crank sensor etc.
Unplugged PCM connector & checked with test light from BAT+ to the PCM connector Pins # B11,B12,B13,&B14.The test light lit bright on each.
Checked with voltmeter from Pins #WC7,WC8,&WC9 to ground and have 11.5V
From whence does this failure come?
Nov 9, 2008 at 3:33 PM
  • 75,988 POSTS
What was the coil primary and secondary windings resistances-what is the voltage on the coil's positive terminal when key at run position
Nov 9, 2008 at 3:58 PM
OLDTIMER10
Primary side is zero Ohms with continuity. Secondary's are within range.
Nov 9, 2008 at 4:10 PM
  • 75,988 POSTS
Do you have an HEI distributor or DIS See below info and also check the distributor pick-up coil
https://images.2carpros.com/forum/automotive_pictures/12900_d1_3.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_d2_3.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_d3_1.jpg
Nov 9, 2008 at 4:25 PM
OLDTIMER10
I believe it is a DIS waste spark system.
Coils have been load tested independent of engine with same weak spark. Also tested new coils with same weak spark. I believe I have a grounding problem. Can you tell me the locations of ground straps from engine to body?
thanks
Nov 10, 2008 at 2:48 AM
  • 75,988 POSTS
Check ground point G120 above the AC compressor
https://images.2carpros.com/forum/automotive_pictures/12900_pcm_ground_1.jpg
Nov 10, 2008 at 6:01 AM
OLDTIMER10
Removed wires, cleaned and applied dielectric grease at G120.
Also, checked b11-b14 with multimeter which check ok.
Thank you
Nov 10, 2008 at 6:10 AM
