1994 Buick Lesabre coil packs
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF.C
If coil packs ar bad will they work intermitenly or just stop working?
Feb 19, 2009 at 2:45 AM
ZACKMAN
  • 4,202 POSTS
They can be both. Some will quit working completely. Some will work intermittently.
Explain in detail what you are experiencing. We may be of help.
Feb 21, 2009 at 3:40 PM
JEFF.C
I no longer think coil packs. I have spark but won't start. So I spray starting fluid in the intake it fires instantly one more shot its running. I drove it home it ran great. Went to start it the next day would not even fire. I took the vaccume hose off the pressure regulator valve it started for couple seconds but dies. Replaced TPS and camshaft sensor. Not sure what next. Thanks for the help don't have much money got laid off.
Feb 22, 2009 at 1:09 AM
ZACKMAN
  • 4,202 POSTS
Test your fuel pressure.
https://images.2carpros.com/forum/automotive_pictures/55316_94lesabrepressure_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_94lesabrepressure2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_94lesabrepressure3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_94lesabreunderhood_1.jpg
Fuel pump relay is inside passenger compartment relay center, behind right side of dash.
Feb 22, 2009 at 2:55 AM
